Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $4,333.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 09-23-2009, 03:28 PM
Berliner Bel Air's Avatar
Berliner Bel Air Berliner Bel Air is offline
Beyond the Sea
18V ignition, anyone tried this?
On another forum I picked up a reference to supplying a coil with a higher than normal voltage, say 18-20V, presumably fed through the electronic module first using a booster DC converter (or even a 6V battery in series for a short while) with a standard inductance type ignition system. Has anyone here have any experience with this? The long and powerful spark which would result (if it works) would help to push the cruise lean burn envelope, which is my intention.
I intend to use a Pertronix Ignitor II and would like to know how much voltage this unit can safely handle, also any other experience/warnings would be appreciated. I searched the archives but couldn't find anything relevant.
Old 09-23-2009, 06:39 PM
neverfastenuff neverfastenuff is offline
If you go to DUI or performance distributors the have a product called the minivp which ramps up the volts to 18 just to the ignition. It looks to be very interesting and I am thinking of getting one myself. I'm currently using their street/strip hei distributor and I'm happy with it and there customer service. Good Luck
Old 09-23-2009, 06:47 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Terrified Of 350 Rockets.
Just from my point of view, I don`t see how this would do any good. You can give a ignition system all the volts you want along with amperage and it won`t make any more power than it did with a stock HEI. Increasing fuel and air make more power, give it the proper spark at the proper time and you`ve got a winner.
Old 09-24-2009, 12:47 AM
Beyond the Sea
I see your point about there being no advantage, but I should have added that I intended to take advantage of the increased energy by substantially increasing the spark plug gap, to be able to light off very lean mixtures in the range of 17-19 AFR.
Old 09-24-2009, 03:30 AM
upstand2 upstand2 is offline
I just picked up an Accell unit for $56 new. It does the same thing as the mini VIP but only above 3000rpm. I figure it can't hurt for boosted applications and 3000rpm happens to be where my turbo makes full boost. Also because the accell unit only activates above 3000rpm it should save the coil some.
Old 09-24-2009, 04:28 AM
barnym17 barnym17 is offline
I've done it with an hei it works well.But there are drawbacks if you have the switch on for any length of time without the engine running you will fry the module.We used it in a restricted circle class that didn't allow an msd it allowed larger gaps up to a point then you hit wire leakage.The main advantage was it extended the rpm range of the stock module higher without missfire.
Old 09-24-2009, 07:13 AM
Argess Argess is offline
I doubt you need 18 volts for a properly working ignition system. The spark voltage is dictated by the gap and any excess voltage is taken up by resistance elsewhere.....wires, etc. The spark may last longer,, so more energy, but you should already have enough with a properly wroking system.
As far as using 18 volts with a non-points dist, it probably won't burn out any electronics, but I would go to the manufacturer's web-site and stick within their supply voltage specs. If it's stock EI, then maybe try it with another unit from the junkyard first.
The only reference I heard about using 18 volts was for track cars that ran without an alternator. A partially discharged 18 volts battery (or a 12 and a 6 in series) is still over 12 volts where the 12 volts battery may discharge to the point the igntion starts to misfire.
Old 09-24-2009, 08:13 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Streetbeasts lawsuit donor
If you want current to light a gap get a magneto.
Outlawed tunes from outlawed pipes
Old 09-25-2009, 04:03 AM
What you are wanting to do is the original reason the msd system was conceived in the early 70's.I suspect you are trying to get really good mileage for cruising from the question if so msd style system would probably be the way to go.The multiple sparks in the cruising rpm range would give the lean mixture a better chance to ignite.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "18V ignition, anyone tried this?"
no power getting to my ignition coil dearta223 Electrical 1 08-01-2009 08:36 PM
ignition swith problem 302 Z28 Electrical 3 02-01-2009 08:14 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 09:10 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 04:11 AM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 05:42 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
