Basic generic info.
The mounting surface of the water neck should be flat. Check/correct this by placing some medium grit emory paper on a sheet of glass (or any other known flat material) and lightly sand the water neck flange checking to see that all the flat surface has been cleaned up. Use a new gasket with a good sealer. I like Permatex non-hardening brand.
If the water neck has an 'O' ring instead of just a paper gasket; then apply a liberal amount of Vaseline (petroleum jelly) to the 'O' ring and install. Check the 'O' ring for cracks and/or breaks and replace if necessary.
In either style, be sure that the flange of the thermostat is fully seated in the intake before installing the water neck.
Tighten the mounting bolts (or nuts if using studs) evenly and torque to specs.
