1923 T Bucket Complete brake system run-thru - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2011, 05:43 PM
OK.... I need some help. I probably know what I am asking, but before I put out money I would like to verify my thoughts! I am knee deep in a 1923 "KIT" T Bucket project. I am coming up on mile marker "Brake system" and would appreciate any input! I am using speedway as my purchase point, if anyone has a cheaper more durable company I would like that info also! I have the brake master cylinder installed, now for the rest... I am looking at an adjustable proportioning Block with a built in brake light (one less flare I need to make) Speedway website P/N 910-31358-BLK. I also "think" I want to run SS lines thru-out the frame and to the calipers. The block above mentioned makes it so that i can run the individual lines from to block to each of the 4 wheels. Would this be the preferred method? Would a single line with a "T" at the rear end look and and function best? What flare type would I use for this block, and what flare type would I use for the calipers? Should I end the hard line at the shock on the rear axle and go to flexible braided line? What flare would I need if I used the flexible braided line? And tips or tricks or pictures of installed brake lines to help a first time rod builder out would be much appreciated! Thanks and happy trails on the Ole gassers!
Old 01-11-2011, 05:55 PM
Pics of 1923 T bucket progress!
Here are some pics... Ill post along the way and hope for tons of advise from the experienced builders! The hotwheels car is what I hope the bucket looks like when done!
ID:	51601   Click image for larger version
Name:	nats pics 037.jpg
ID:	51602   Click image for larger version
ID:	51603   Click image for larger version
ID:	51604   Click image for larger version
1923 t bucket John Steiner Suspension - Brakes - Steering 13 12-15-2010 07:56 AM
1923 ford t bucket robert holmes Introduce Yourself 2 01-02-2008 01:55 PM
1923 T bucket boom5117 General Rodding Tech 4 05-19-2006 08:12 AM
1923 T Bucket Perch fsanfi01 Suspension - Brakes - Steering 3 01-01-2003 04:37 PM
