1923 T Bucket Perch - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2002, 10:27 AM
Post 1923 T Bucket Perch
I just purchased a 1923 T bucket and need to change the 6" perch it now has to a lower one. The front pipe it is welded to is 2 and 3/8 inch dia. Does any one know of a place that I can purchase a perch of this diameter? I already tryed TPerformance and Speedway Motors, there perches are 2 and 5/8" and 3". Thanks. Frank....
[ December 31, 2002: Message edited by: fsanfi01 ]</p>
Old 12-31-2002, 11:44 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
2 3/8" is a standard oilfield pipe!
Old 12-31-2002, 07:18 PM
Post
Frank,
You could just make one from scatch,just cut the side plates off the one you have(you can reuse the center section with U bolts) cut some new side plates to get the ride height your lookin for. We used to make the flat part of the perch at the center of the pipe, with a reverse eye spring this gives a pretty low stance.
Later, Mark
Old 01-01-2003, 05:37 PM
Post
Thanks Mark. I have some pics if you want to see. Apic is worth a thousands words. Frank...
