1927 ford coupe rear suspension question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 12:42 PM
pi71's Avatar
it will have a v8 ford 8" rear with radius rods and airshocks or coilovers, should i install a panhard bar or watts link? just a weekend driver no dragracing(well maybe once or twice)
Old 11-27-2007, 12:55 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I used a panhard bar on my A model. Four bars and coilovers. It does just fine
Old 11-27-2007, 07:41 PM
The Maintenance Geek
If you use a panhard bar, make it as long as possible.
The cars rear end won't feel as though it's moving a lot
over the bumps...
K
Old 11-28-2007, 06:09 PM
Youngster's Avatar
1927 Ford coupe rear suspension?
If by air shocks you re talking about air assist shock absorbers, ditch that right now. They are not acceptable as primary springing. Go with the coil overs for the most trouble free set up. The Watts link will give you the best ride of the two, but the panhard bar will be easier to set up. Another choice would be air bags, but there again, the coil overs are easier to set up.
Youngster
Old 11-28-2007, 07:15 PM
Wiki Edits: 49
You should use a wats link or pan-hard bar to be safe. The pan-hard bar is the easiest and as someone already said make it as long as possible. Short bars tend to make the rear end move from side to side much more than longer ones. Coil overs are fine as is an air ride setup. Don't use air shocks.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
40 Ford Coupe Rear Seat Dirtbillr Interior 2 05-30-2007 05:40 PM
'41 Ford Coupe , windshield division bar question Bob 1743 Body - Exterior 1 05-13-2007 06:58 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
question for all you ford suspension guys Blag Suspension - Brakes - Steering 7 03-29-2005 11:59 PM
