1927 Model T Tudor Sedan - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-24-2006, 06:54 PM
Hi
I have a 1927 Model T Tudor Sedan and have been collecting parts for a long time and I want to use a 5.0 Fuel Injected Engine, Overdrive Trans., 9" Rear, and Straight Front Axle w/ Rack and Pinion Steering from a 53 or 54 Ford F1 Pickup but it is too Wide. I would like to know if you can NARROW A STRAIGHT AXLE without damage to the axle or ability to align the front end? Any and all helpful info is well appreciated. I do not have the income for fancy items out of books so please help with good info that an Old Rodder on a fixed income can afford and use.
GOD BLESS
nejnej99
Old 03-24-2006, 08:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders. Just get you a brand new straight axle for your T . You can get them at www.speedwaymotors.com You will probably want a dropped axle anyway. This forum is for introductions, not questions so next time please place your questions in the proper forums. Thanks.
Old 03-25-2006, 05:35 AM
32chevy vett's Avatar
32chevy vett
1927 model T Tudor Sedan
Originally Posted by nejnej99
Hi
GOD BLESS
nejnej99
Don't even think about it if you can't afford a new one go to sum swap meets you will find sum thing that will work.And it will be SAFE.
Model T Frame adtkart Suspension - Brakes - Steering 19 01-07-2008 09:53 PM
Which would be preferred for a 1927 Model T: Manual or Automatic transmission? jesseeee Transmission - Rearend 5 02-17-2006 07:39 AM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
confusing question about cars and their weight stonedchihuahua General Rodding Tech 14 03-27-2003 03:00 PM
