1928-1932 Desoto, Chrsyler or Dodge Coupe?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2003, 04:10 PM
Post 1928-1932 Desoto, Chrsyler or Dodge Coupe??
Does anyone have knowledge of these cars. 1928-1932 Desoto, Chrysler or Dodge Coupe?? I have a body and chassis which I believe could be any of the cars named in the subject line. Does anyone have pics they could share of such cars? I have had the car for about 3 weeks and no one has been able to identify it yet.
Thanks
Dave
Old 06-04-2003, 05:05 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Post
<a href="http://www.geocities.com/heatzero/1951-DeSoto/DeSoto1928-1961.htm" target="_blank">http://www.geocities.com/heatzero/19...o1928-1961.htm</a>
<a href="http://www.geocities.com/heatzero/1951-DeSoto/DeSoto1928-1961.htm" target="_blank">[url]www.geocities.com/heatzero/1951-DeSoto/DeSoto1928-1961.htm" target="_blank">http://www.cnystreetrods.org/memcars/tn_mikeo.jpg</a>
<a href="http://www.conceptcarz.com/img/dodge/thumbnail_img_0_32dodgecpe.jpg" target="_blank">http://www.conceptcarz.com/img/dodge...32dodgecpe.jpg</a>
I could post more pics, BUT why dont you use your search engine on your computor & type in the make of car, you'll find some pics, or better yet post a pic of your car & maybe someone will know...joe
well there were pics on here but they're gone now.
Old 06-05-2003, 07:54 PM
Post
There are several ways to begin the quest to identify your "unknown" car. Look for a firewall tag or cowl tag. These usually indicate the Manufacturer and sometimes even the year of manufacture.
The shape of the rear window is sometimes a good indicator at least of manufacturer, though not necessarily the make.
Do the door open from the rear or from the front(suicides).
Is the body structure mostly wood or steel using wood around the window openings and the top hole?
Does the car have a cowl vent or two?
Does the windshield tilt out for ventilation or roll up?
Is the suspension dual leaf springs at the front and rear?
Are the brakes hydraulic? All Chrysler products from 24-up have hydraulic brakes. GM started in 1936. Ford started in 1939.
Get a copy of the The Old Cars Weekly Auto Identification book printed in Iola, WI.
Old 06-08-2003, 04:07 AM
Post
try the tinman mike tipton hes building 32's in fiberglass ive got a thirty four dodge coupe but im down under in Aust. mike has a great web site try the search engine good luck some picks of my coupe are on klassic 100 's photo album see ya ian
Old 06-11-2003, 10:31 PM
Sandflea427SS's Avatar
Anything with a throttle
A friend of mine restores cars and I just helped him pick up a '30 Desoto. I will try to post some pictures in my photo album. I could also check the car out to match any points of reference you might have! Let me know if you need anything.
Old 06-13-2003, 04:43 AM
woodz428's Avatar
Troll Hunter
Arrow
It would make it easier if you posted the pics of the car and then it could be identified much esier. Having others posts pics and then having you check seems to be backwards.
Old 11-15-2012, 06:39 PM
question about car
i know this is a long shot, and your post is from some years back, but can you send me a picture of your car/parts? was it a desoto? my email is texley77(at)hotmail(dot)com
thanks
tony
Old 11-15-2012, 08:52 PM
Crosley's Avatar
Wiki Edits: 1659
thanks
tony
iniguy has not logged in since 2006 ... there may be no answer
