1928 Buick Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2009, 08:19 PM
Soul Survivor
1928 Buick Build
I thought you guys might like to see this old gal...I started on her in March, drove her 66 days later.
Old 06-23-2009, 08:23 PM
Soul Survivor
Used a Speedway Motors axle and brake set up in the front.
Broke up some new running boards.
Cleaned up the bumpers.
Old 06-23-2009, 08:26 PM
Soul Survivor
Used a disc brake S-10 axle for the rear, used the stock spring set up (minus two leaves) and ladder bars.
I was missing the drivers window garnish so I used the passenger side to go by and just made some.
Old 06-23-2009, 08:30 PM
Soul Survivor
The engine is a .030 over 350.
Rolled it outside for the first time since I got it and degreased the frame and engine bay.
I have a new stock tire and wheel which I think I'll keep on the back.
The engine is done other that the intake and fuel system.
Old 06-23-2009, 08:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sweet ride . Cole
Old 06-23-2009, 08:35 PM
Soul Survivor
Mocked up the engine and started the engine and trans mounts.
Have about an inch between the drive belt and the fan housing.
Brake pedal assembly mounted.
The stock gauge holes were oval so I took an old dash from a M151 military jeep and graphed it in to hold standard size gauges.
Old 06-23-2009, 08:37 PM
Soul Survivor
Everything fits pretty good.
Old 06-23-2009, 08:39 PM
Soul Survivor
Brakes and wiring finished.
Old 06-23-2009, 08:42 PM
Soul Survivor
I like the cowl lights, wired them up on the "accessory" side of the switch for park lights.
It's good to have the seats back in.
Old 06-23-2009, 08:45 PM
Soul Survivor
Been driving it around watching for bugs, so far so good.
Old 06-23-2009, 09:11 PM
life is a temporary assignment
Very nicely done..
Old 06-23-2009, 10:20 PM
Looks great What kind of compression/boost are you running?
Shane
Old 06-24-2009, 07:25 AM
cboy's Avatar
Last journal entry: Finished
Wow, impressive build for 66 weeks...much less 66 DAYS. Very nicely done.
Always learning...and sharing what I've learned.
Old 06-24-2009, 07:34 AM
Soul Survivor
Thanks guys, I'm running about 9:1 compression and 4lbs of boost.
Old 08-11-2009, 07:59 PM
Soul Survivor
The 16" fan I had on it died going to the Elizbethton Cruise-in Saturday night so I put this Taurus fan on it, fits perfect.
Just finished painting the fenders and running boards black like they are supposed to be.
I used Rustoleum Semi-Gloss black, once it cures out it will be about the same gloss level as the original black on the top section.
Buick 350, build or swap? classic747 Engine 11 10-13-2009 08:31 PM
b or g hemi joe Body - Exterior 5 05-03-2009 02:50 PM
my buick daddyrain Engine 13 11-16-2004 10:09 PM
'57 buick vs. '27 roadster 27trackt General Rodding Tech 4 06-30-2003 06:16 PM
