Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1929 ford dropped suspension
Old 01-31-2013, 08:00 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you like the ride and the wheel and tire combo but it is just too low, you can either install a spacer like you mentioned (I usually just make one out of .250 wall rectangular or square tubing and box the ends) or you can re-arch the spring. With the spacer, you will need to get new U-bolts made up. It might be cheaper to re-arch the spring.
Regards,
Andy
