1929 ford dropped suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2013, 05:36 PM
I recently purchased a 1929 ford tudor. Its 80% complete at the moment, but an issue I have is the front suspension. I believe its a 2" tube drop, and I have 165/R60-15 front tires and they strike the fenders when I turn or hit a bump. It looks like the drop is too much and I need to place a 1-1/2 - 2" spacer between the cross member and the leaf spring center mounting. Does anyone make a spacer for this?
Old 01-30-2013, 05:40 PM
Do you have any photos, a 2" drop isn't much, I think it was darn near that much stock. That doesn't change your problem of course but maybe with a photo showing what you have a solution could be found. It could be as simple as changing the rims because they have too much offset.
Old 01-31-2013, 08:00 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you like the ride and the wheel and tire combo but it is just too low, you can either install a spacer like you mentioned (I usually just make one out of .250 wall rectangular or square tubing and box the ends) or you can re-arch the spring. With the spacer, you will need to get new U-bolts made up. It might be cheaper to re-arch the spring.
Regards,
Andy
1929 Ford Hot Rod won't start 29Roadster Electrical 8 09-11-2010 10:44 AM
Dick and Sue Allan, blown hemi 1929 Ford roadster from the 1970's rikard454 Hotrodders' Lounge 0 07-10-2009 02:23 PM
Brakes for a 42'-47' Ford Dropped Axle ATX30Sedan Suspension - Brakes - Steering 1 03-04-2006 01:46 PM
Ford dropped axle on a 37 chevy p/u junkyardjeff Suspension - Brakes - Steering 1 12-17-2005 07:27 PM
1929 ford-cabriolet ezdog Introduce Yourself 1 11-27-2005 12:50 PM
