1929 Ford Hot Rod won't start
I have a 29 Ford Hot Rod, 351C C4 auto. It's been reliable over for some time. Just the other day it decided that it would not start up. All i got was a click at the starter, but it would not turn over at all. I've put in a new battery, starter, solenoid, ignition switch. The engine does turn over by hand. There are 12V at the starter. I've shorted it at the solenoid and still only get a click. When i turn the headlights on and turn the key the lights don't dim. Any thoughts?
Hot Rod won't start - help please
Moderators note: I merged your two threads into one, please only post one question on the same subject.
Thank You Vince Last edited by 302 Z28; 06-28-2010 at 09:34 AM. Reason: Violation of guidelines. Please see: general board guidelines. |
....and once you have checked those cables and if you find nothing wrong, then it's a better then even chance it's the starter, particularly if you've been using a original style. A little different engine, but my last 351W ate a rebuild or two a year until I went to a decent Summit after market unit - and it's the same starter. The symptom - a clicking solenoid.
Dave W |
If you went straight to the starter and it doesn't work, its the starter....either its jamming or its beat...take it off and bench test it
Ontario Rodders |
Fixed!
I really appreciate all of the advice!!!! Went through the electrical, grounds, etc.. removed the new starter and bench tested it and the new powermaster turned out to be bad. Replaced it and it's running great once again.
Bad Ground
Dan |
| Getting a hot rod titled in Wisconsin | cboy | General Rodding Tech | 3 | 07-26-2009 02:28 PM |
| My First Hot Rod!... project | TexasTechX1 | Hotrodding Basics | 46 | 04-21-2009 07:40 AM |
| So What is A Hotrod | Ratchet | Hotrodders' Lounge | 63 | 10-05-2006 01:11 PM |
| 1950 Ford PU Hot Rod | boonie | Introduce Yourself | 2 | 02-09-2006 09:56 PM |
| Hot Rod of the Week suggestions? | Jon | Hotrodders' Lounge | 30 | 06-02-2003 04:53 AM |
