Scroll down here for a shortie water pump...
http://www.snowwhiteltd.com/products.htm |
firewall fit
I bought my A as an unfinished roller. with 302, auto. the builder recessed the firewall, not enough for the aluminum valve covers I want to use. How's the oil pan clearance? if you need more room you can get either a Bronco (expensive) oil pan and pickup tube , or 80's mustang V8 pan and tube parts.
260 info
The 260 is part of the the small block ford family 221 260 289 302 then modified for the 351 W, dimensions are the same except the 351 is a little taller and wider and not a lot of 351 parts interchange. the 221 and 260 have a different bell housing pattern, the valves are smaller. most people stay away from 221-260 unless they are doing a restoration. they are a good engine in a light car like your A good milage and plenty of power for a driver.
You'll hate yourself in the morning if you don't do something about that back bolt, like pulling the motor forward so you can get a wrench on that. Short water pump like in the link Techinspector provided will help a lot with not pushing this lengthy motor through the radiator while being able to get at the buried bolt. Murphy's Law insures that if you leave this like it is, the first thing you'll have to do after it's all built and polished up is pull the intake and there will be that bolt as defiant to removal as possible. Bogie |
you could machine (or grind) the boss on the back a little to clear a slightly shorter bolt or you could put a torx headed bolt (button head style torx) in there as the head would be a low profile and may clear pretty good. There isnt a good option for clearance to remove the intake in the car as it looks,unless you chop cut rebuild that area.something you may or may not be wanting to do.
I see now that it is on the drivers side of the motor ( i saw the number8 there) that side will tend to lift as you accelerate so any clearance you gain would be good. Of course I might just be preaching to the choir here. |
You may want to eliminate the Oil pressure switch extension also as it looks as though it will interfere with the steering shaft. Just noticed thought it was worth the mention.
Welcome to the world of Brookville.
Now, let's see what has to be modified to make a SB Ford fit: - Firewall. Unless you opt to run the late model serpentine belt arrangement and short pump, that firewall will need at least their 3" recessed version, and even with that set up, probably needed anyhow. The 5" will be better as it will give you even more engine room but might kill your foot room. You can also cut their motor mounts out and move the engine back - use the stock/standard pump along with the mechanical fuel pump (which will not work with the serp arrangement) - Bolt/intake interference - yep, intake as well as the bell housing will need some clearancing regardless of the transmission used. Here are some photos of mine which has an even greater setback, killing my foot room, but can be worked around. This is a Brookville body, TCI chassis: http://s70.photobucket.com/albums/i8...t=DSC_0076.jpg ![]() ![]() ![]() ![]() This is a 3.5" recess with an additional 2" deep lower recess to clear the bell housing/bolting It is not a difficult project, but you do have to do some planning as well as taking the time to do a good fit. My engine trans combo is a 302-5.0/C4 which dimensionally is identical to your 260, using a stock length water pump, tho a Stewart's NA$CAR version and with my setback, could have used a mechanical fan Other photos available if you need them for a "guide" Dave W Last edited by Irelands child; 04-10-2011 at 07:47 AM. |
| Anyone install a lates model Ford 3.8L? | CALI4N1A | Engine | 2 | 01-26-2011 02:24 PM |
| 1930 ford model a coupe seat removal | ONEGALONLY | Interior | 1 | 11-08-2008 12:49 PM |
| 1930 model a | thinksnow | Hotrodding Basics | 6 | 01-22-2007 07:47 PM |
| Frame Specs for a 1930 Ford Model A | superduty50 | General Rodding Tech | 3 | 01-29-2006 12:05 PM |
| ford 9 inch under a 1930 model a | 30sedanman | General Rodding Tech | 6 | 07-25-2005 01:05 PM |
