1930 model A coupe fender/running boards removal?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 01:52 PM
pi71's Avatar
How hard is it to remove the fenders and running boards from a 30 model a coupe.. just bolted on ????welded??rivets??
Old 04-15-2006, 01:57 PM
Wiki Edits: 31
bolted on.
Old 04-15-2006, 03:29 PM
The only hard part is the running board aprons, those need the body lifted to get out as I remember. Or at least the body bolts removed. The rear fenders have a number of bolts to the body, then a couple at the apron then a few at the running board. Then the front are similar with a few going thru the top into the frame.
1930 model a question pi71 Hotrodding Basics 3 04-12-2006 10:04 AM
Selling 1931 Ford Model A Coupe cassadyadj Introduce Yourself 1 03-29-2006 04:27 PM
Model A Coupe rodsterv8 Introduce Yourself 2 03-03-2006 12:26 PM
1931 Ford model A coupe Pontiacman Engine 2 07-31-2005 12:04 PM
1930 Coupe Doors? SuperFrog Body - Exterior 3 03-06-2004 04:53 AM
