1930 model a question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2006, 12:16 AM
pi71's Avatar
can you put a regualar 5 lug wheel on the 5 lug stock hub of a 1930 ford model a?? thanks (in place of the wire wheels....
Old 04-12-2006, 07:16 AM
Frisco's Avatar
Glad To Be Here
Yes. Just get a wheel with the correct bolt circle and number of lug holes. Look at mid fifties Ford pickup or some Chrysler products rims for 15". '40-'48 Ford or Merc for 16". You can also buy new from Wheel Vintique, Coker Tire and others.
Old 04-12-2006, 07:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Unless you have wide 5 it is 5 on 51/2 bolt pattern..Ford pickup or later steel wheels fit that bolt pattern..
Good luck on finding a wheel that suits ya....
Sam
Old 04-12-2006, 10:04 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
A search of the Knowledge Base for "wheel bolt pattern" gave these results:
http://www.hotrodders.com/kb/search....&searchid=8223
Scroll down to the 5 X 5 1/2 bolt pattern and you will find all the wheels that fit on a Model A.
As well almost every aftermarket reproduction or custom wheel company makes wheels for the Model A bolt pattern.
Model T Frame adtkart Suspension - Brakes - Steering 19 01-07-2008 09:53 PM
'85 model 305 timing question kf4ozb Engine 2 07-27-2004 01:58 AM
turbo draw-thru question deuce_454 Engine 7 05-11-2004 01:51 AM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
