1930u Adjustable Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 08:02 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Just started back to work on the Hot Rod after a long sabbatical. Today I made up a bracket and mounted the proportioning valve. I wanted to put it in a protected spot that was easy to access. Now that I've done the work I don't like the way it looks. Maybe it's the purple anodized coating.
I might change it out, or at least strip off the anodizing before I drill, tap and install the line clamps.
Old 11-28-2011, 03:16 AM
SSedan64's Avatar
Just Spray paint it your choice of Color.
Old 11-28-2011, 05:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Glass beading will rid it of the anodizing. If that's not practical, a strong base removes the aluminum oxide surface treatment and exposes the untreated aluminum beneath. Lye (sodium hydroxide) will work, as will a cleaner like Driveway Cleaner sold in parts stores, Black Maxx (NAPA), or any of the more concentrated alkaline cleaners like that will work.
If you use lye or strong cleaners of any type, dilute it to the weakest solution that will still do the job. Use eye/hand/body protection and keep a supply of fresh water on hand just in case.
1930u which valve covers to use 1930u Hotrodders' Lounge 20 02-19-2011 07:15 AM
proportioning valve mac350 Suspension - Brakes - Steering 4 09-28-2010 05:21 PM
adjustable proportioning valve leaking at stem cboy Suspension - Brakes - Steering 3 04-23-2006 04:19 PM
proportioning valve fred56 Suspension - Brakes - Steering 11 12-21-2005 02:46 PM
Adjustable proportioning valve for drum system? MM in NM Suspension - Brakes - Steering 1 11-10-2005 10:04 PM
