1930u Getting the right early 70's stance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2011, 07:45 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Here's a few pics. taken today. I'm pretty happy with the way it looks but the engine is raked down in the rear a little more than I care for. I have adjustment slots on the bell housing mounts so I can raise it up no problem. Just thought I'd get a few opinions from the group.
ID:	61125   Click image for larger version
ID:	61126   Click image for larger version
ID:	61127   Click image for larger version
ID:	61128   Click image for larger version
Old 12-27-2011, 10:57 PM
Hotrod Hirning's Avatar
New Member
stance
You want the engine and trans to be in direct straight line with the rearend yoke. The stance is fine. You might get the radiator back behind the front axle.
Old 12-28-2011, 03:12 AM
Last journal entry: A few ongoing projects
The biggest concern I would have with the amount of engine tilt would be getting a decent pinion angle.
Old 12-28-2011, 05:46 AM
jon72vega's Avatar
WOW, I could have had a V8!
What the other guys have said about the proper angle relationships is true.
With that being said, you are building one sweet ride!
That is going to be wicked when you are done!
Jon
http://1972vega.wordpress.com/
The Following User Says Thank You to jon72vega For This Useful Post:
1930u (11-17-2014)
Old 12-28-2011, 09:53 AM
Frisco's Avatar
Glad To Be Here
The engine should be set up so that the carb mounting surface of the intake manifold is level from front to rear and from side to side. This will allow the carb bowls to fill correctly and function correctly. It will also yield the crankshaft centerline down at the rear approximately 3-4 degrees. That is a common down angle for the engine/trans and will allow the u-joint to perform as designed without premature wear or binding.
At the present, looking at the photo's above, it appears that the crank centerline is down at the rear closer to 6 degrees. That would be too much for street use. It can be corrected by either lowering the front of the engine at the engine mounts or raising the rear at the trans mount.
For street use the centerline of the pinion shaft of the rear axle carrier should be up the same number of degrees that the crankshaft centerline is down. i.e. engine down 3-4 degrees with the trans up 3-4 degrees.
The end results should have the engine crankshaft centerline parallel to the pinion shaft centerline looking from the side and from above.
For drag strip only the pinion shaft centerline of the rear axle carrier should be down to allow for the tendency of the rear axle to rotate up when under hard acceleration.
Old 12-28-2011, 06:07 PM
1930u's Avatar
All your info. is greatly appreciated. I have plenty of room for adjustment at the engine and trans. Thank you!
Old 12-29-2011, 10:21 AM
Frisco's Avatar
Glad To Be Here
Just for a visual comparison. Here is a pic of a modified version of your coupe. The engine has been tilted up at the rear three degrees from where you show it in your original photo. The engine sits with the carb bases level to the ground in this pic. I didn't fix the fence rail in the background so you can see the changes. Left click for a larger view.
Second pic is where the bottom of the tires are level with each other (Original pic tilted 2 degrees up at the rear and the engine has been tilted up an additional 2 degrees at the rear).
Name:	engine tilted 3 degrees up at rear.jpg
ID:	61183   Click image for larger version
Name:	Body level engine rotated 2 degrees.jpg
Old 12-29-2011, 06:10 PM
1930u's Avatar
Thanks Frisco. It should work out fine. I have plenty of adjustment front and back.
Hot rod stance 77bronco_ed Suspension - Brakes - Steering 3 07-27-2011 08:23 PM
Early 70's 390 valve problem Hippihogg Engine 10 03-21-2011 12:53 PM
Resto Rod Stance k.c. General Rodding Tech 7 01-27-2011 10:39 AM
early comet engine swap (or early mustang) REALGONEKATT Engine 14 11-04-2007 07:15 PM
Getting the stance BMM General Rodding Tech 1 09-19-2006 07:18 AM
