1930U Swing Pedals Right Angle Master Cyl - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2009, 07:23 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Since I decided to bring in a professional to do the mud work...I have moved on to other areas. I roughed in the pedal mounts last year and now I'm doing the final work. When I'm done with the pedals and dash frame work I plan to install a hinged fuse panel mount just to the left of where the steering column will mount. I'm going to use the original dash panel and a mixture of Plymouth and Hudson gauges and bezels.
Here's a pedal pic.
Wilwood Pedals and Master Cylinders Dugg Suspension - Brakes - Steering 17 02-04-2008 02:53 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 01:48 PM
Stock Monza Master Cyl work with aftermarket disk brakes? Quarter Flash Suspension - Brakes - Steering 1 11-19-2006 05:31 PM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 12:47 AM
Relocating master cyl on a 34 302 Z28 Suspension - Brakes - Steering 8 11-16-2003 10:42 AM
