1931 chevy 5 window coupe build thread - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 06-23-2013, 05:51 PM
Ok guys, this is what I started with. Original motor, trans., and rear.
Old 06-23-2013, 05:55 PM
doing some bodywork, a little dent in the top and a few in the fenders. Also painted the dash.
ID:	75115   Click image for larger version
ID:	75116   Click image for larger version
ID:	75117   Click image for larger version
ID:	75118   Click image for larger version
Old 06-23-2013, 06:02 PM
pulled the motor, trans, rear end. replaced rear with 2000 S-10. Motor with 4.3 V6. and the trans with a 2004R.
ID:	75120   Click image for larger version
ID:	75121   Click image for larger version
Old 06-23-2013, 06:04 PM
took it apart to replace stock front end with mustang II. Also painted firewall.
ID:	75123   Click image for larger version
ID:	75124   Click image for larger version
ID:	75125   Click image for larger version
Old 06-23-2013, 06:08 PM
The wheels that I'm using.
ID:	75127   Click image for larger version
Old 06-23-2013, 06:10 PM
dropped the rear 3 in. and got some primer on it.
ID:	75129   Click image for larger version
ID:	75130   Click image for larger version
Old 06-23-2013, 06:25 PM
got the frame boxed, and mustang II welded in. pics. of lowered rear. And as bad as I hated to do is cut my fender to make room for upper a arm.
ID:	75132   Click image for larger version
ID:	75133   Click image for larger version
ID:	75134   Click image for larger version
ID:	75135   Click image for larger version
Old 06-23-2013, 06:27 PM
pic. of motor and trans. will try to keep you updated. thanks Joe
ID:	75137   Click image for larger version
Old 06-23-2013, 08:14 PM
I need some idea's on how to cover up my upper A-arm. Thanks Joe
ID:	75143   Click image for larger version
Old 07-27-2013, 03:17 PM
Just started reading your thread. Nice job on a nice car. I have a 31 sedan, 2 door.
Are you interested in selling the original front end assembly?
Old 07-27-2013, 03:34 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
How about making a bullet style blister that you weld to the fender? Use a piece of thin wall tubing and a couple weld caps, then cut the tubing to use 90 segment. Some ideas here too: http://www.jalopyjournal.com/forum/s...d.php?t=166194
Old 11-30-2013, 07:31 AM
got my hood, rad. and tail lights mounted.
Name:	31 grille update 003.JPG
ID:	101874   Click image for larger version
Name:	31 grille update 002.JPG
ID:	101882   Click image for larger version
Name:	31 grille update 004.JPG
ID:	101890   Click image for larger version
Name:	31 grille update 005.JPG
Old 11-30-2013, 11:16 AM
455olds's Avatar
Great looking car!
Old 11-30-2013, 02:08 PM
Fun, fun, fun!
Old 12-15-2013, 06:43 PM
got my steering done, brakes on the front. and electric fuel pump mounted. Also got a new set of tires on the back.
Name:	31 chevy 12-15-2013 001.JPG
ID:	105418   Click image for larger version
Name:	31 chevy 12-15-2013 002.JPG
ID:	105426   Click image for larger version
Name:	31 chevy 12-15-2013 003.JPG
ID:	105434   Click image for larger version
Name:	31 chevy 12-15-2013 004.JPG
ID:	105442   Click image for larger version
Name:	31 chevy 12-15-2013 005.JPG
1931 chevy coupe body dac_butch Body - Exterior 3 04-22-2012 09:03 AM
Build Me A 32 3 Window Coupe cpinkerton Hotrodding Basics 9 01-04-2009 05:24 PM
chevy 3 window coupe pi71 Hotrodding Basics 29 12-13-2006 09:37 PM
1931 ford 5 window coupe jayco Body - Exterior 2 03-26-2006 03:50 PM
1931 5 window coupe seat gw1947 Interior 2 12-12-2002 07:08 PM
