1931 model A coupe cowl repair. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 01:37 PM
31 five window
Last journal entry: grill and rear end
Has someone replaced the whole cowl side panels on a 31 model A coupe and where did you get some that fit properly?Thanks.
Old 02-08-2013, 02:17 PM
I have never replaced the whole cowl side so I don't have an answer for you. But I do know that in dealing with reproduction sheetmetal I don't care where you get it, it is going to need work to fit. The amount could be not a whole lot to so much you might as well make it from scratch.
It sounds like you have one that doesn't fit, is that the case? If so post some photos and let's see if we can help you make it work.
Old 02-09-2013, 07:37 AM
31 five window
Thanks. I have come to expect problems,it seems nobody takes pride in what they make anymore.The door jamb area is stamped at a 90 when it should be tighter than a 90.I can,t just hammer and dolly it because of the angle it goes on the car that would make the center too short and leave a bigger gap in the middle than the top and bottom.I have already cut it and tacked it like it has to be and am slowly welding it.Thanks again.
Old 02-09-2013, 08:26 AM
Banned
i know it's been done before, but diamond plate looks good
Old 02-09-2013, 08:31 AM
life is a temporary assignment
I really don't think he want's diamond plate on his side panels..
Old 02-09-2013, 09:23 AM
Done a number of patch panels on those bodies and that is the first thing I thought of when reading your post, that damn edge at the door not being folded enough. The width of them were always off too with the patch being longer than the cowl from door to firewall. That is what makes you a better bodyman and fabricator, working with stuff like that. I have a piece of rail road track about 8 inches long on my bench. I ground the edge of one side of the bottom of the track real sharp. It is perfect for getting a little tighter edge on something like that.
You want to make it fit better before you weld it in not try to make it fit AS you are welding it in.
Old 02-09-2013, 08:33 PM
31 five window
Done,I will post pics tomorrow.Thanks.
Old 02-09-2013, 08:34 PM
31 five window
Thanks,but I am not building a rat rod.
Old 02-10-2013, 10:04 AM
I know you are done with getting these installed but here is that RR track tool I have used for years on stuff like that. I haven't used it in a while so it has a couple of dents in it but a quick run of the grinder over it and it would have a nice sharp edge again.
Old 02-11-2013, 07:58 AM
31 five window
I like that tool,I actually made a small anvil out of some track several years ago. It realy comes in handy for the smaller stuff. I have a real full size anvil for the bigger jobs.
Old 02-11-2013, 08:03 AM
31 five window
Cowl panel installed.
I installed my cowl patch panel after some cutting and welding and grinding,but it came out great. Now for the other side.I need to let my back recooperate first.
ID:	71252   Click image for larger version
Old 02-12-2013, 09:39 AM
Looking good speedy..
Old 02-12-2013, 09:38 PM
31 five window
Thanks. I will get you to come help me when I start the firewall and the floors.You can do it so much faster than me and I want to make Cruisin the Coast in primer in October.
Old 02-12-2013, 09:44 PM
You know I will be there..
The 1931 Model A 7975camaro Hotrodders' Lounge 2 11-07-2011 08:13 AM
1928-1931 Model A Coupe/Roadster Project Car DesertRoseAZT Introduce Yourself 2 05-09-2011 04:32 PM
1931 model a frame golferjc Hotrodding Basics 1 02-19-2011 06:48 AM
Selling 1931 Ford Model A Coupe cassadyadj Introduce Yourself 1 03-29-2006 04:27 PM
1931 Ford model A coupe Pontiacman Engine 2 07-31-2005 12:04 PM
