1932 5-Window Exterior/Interior Door Handles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2008, 05:37 PM
Triple G
I am currently trying to install Exterior & Interior Door Handles and Hardware in my '32 Ford 5-Window Coupe Project ....... HELP!
I have a Rat's Glass fiberglass body with Specialty Power Window Kits and glass already installed. I purchased standard Vintique, Inc. exterior & interior door handles for a '32 Ford (square shaft) and Carolina Custom "E-Z" Inside and Outside Handle Installation Kits. There is an "L" shaped clevis that releases the bear claw door latches (already installed) between the outside and inside door skin, and it works great when I release it with my finger through the fiberglass on the interior of the door. MY PROBLEM IS THE GLASS. When the window goes up and down, it will interfere with the square shaft from the outside door handle and there's very little room for the rods/linkage, etc. to either the interior or exterior handles. When I requested installation instructions from Carolina Custom, I was told they don't exist, because everyone does it "differently". I've looked at hundreds of '32 Ford Coupes and my hardware and situation can not be that unique. I do know that the inside handle needs to be slightly lower than the vertical end of the "L" shaped clevis and the horizontal side goes to the exterior handle, but again, what about the glass? I've heard, pulleys - wires/cables - bell cranks, etc. There has got to be an easier way. I'M LOST ..... again, HELP!
GGG
1932 ford 5 window droddy Body - Exterior 4 03-23-2010 04:10 PM
Building a 1932 5 Window Ford Coupe 32FordVA Introduce Yourself 3 01-28-2006 05:38 PM
Window channel problems.... onebadmerc Body - Exterior 4 03-25-2005 05:42 PM
Before I break it m-hauler Body - Exterior 16 07-20-2003 06:40 AM
1932 FORD WINDOW COUPE matt_cooper Engine 1 11-03-2002 12:48 PM
