1932 body - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 07:26 PM
1932 body
am planing a 32 build , iam new at this . what is a good steel body and frame? brookville, dearborn, etc. thanks for the help john
Old 07-31-2005, 07:38 PM
302 Z28's Avatar
I can give you some good advice, do not rush your purchase. Research it thoroughly, get plenty of input and don't believe anything the manufacturer tells you.
There are several good frame manufacturers to choose from. I love the workmanship on my Roadster Shop frame for my 34. I have seen a Pete & Jakes frame and they are superb also. A friend of mine had a 32 body on order for over a year from Dearborn Deuce, finally canceled the order. That was several years ago, so I hope things have improved.
Vince
Old 07-31-2005, 09:41 PM
As one of the Moderators here.......I would like to
WELCOME YOU HERE.....
The most obvious answer to your question is Henry Ford.....
But you mention repro steel body manufacturers so.........
What kind of 32 Ford body do you want.
The only reproduction steel bodies that I know of are 3 Windows and Roadsters.
Brookville was supposed to have their 3 Window finished by now but are a little behind schedule. Dearborn Deuce had theirs up and going but are having problems too........
There are two or three repro steel roadsters out there......
Brookville is the best IMHO.......but it's NOT dead on. Close but no cigar.....
If you want something other than those........you are looking at fiberglass or finding one of Henry's. Both of mine are original Henry Ford bodies. They are out there. Just not everywhere.
I suggest finding a original car........and paying the money. When you add up all the extra stuff you have to buy with a Fiberglass car......that you get with MOST original cars.......the difference is not that large.
BUT BEWARE.... 1932's are a lot more expensive than Model A's or other vehicles from that era.....
I bought a 32 Ford 5 Window coupe for a friend......4 to 5 years ago. I gave a little over 12 grand........but I got fenders, hood, grill shell, headlights, gas tank, bumpers......all the LITTLE stuff that adds up to big $$$. Plus I sold the original interior and running gear to a restorer.......ending up at a little over 8 grand.
Had less in it than a fiberglass 32 ......
Wescott has the best fiberglass body...IMHO
Gibbon is good but 302/Z28 has had some trouble with his....
Gibbon body woes :pain:
Check out his woes......
The Outlaw 32 3W body has a 34 Chevrolet back window.....and anybody can see it's a Outlaw from 40 to 50 foot ...easy
Some of the others are just plain trash......
Remember .......if it seems cheap (price)...it most likely is....
34 Ford body alignment 302 Z28 Body - Exterior 5 08-20-2012 06:10 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 02:15 PM
1932 roadster body jdavis1995 Hotrodders' Lounge 1 05-17-2004 06:48 AM
