1933-34 ford headlight stands
can you use chopped headlight stands with commercial headlights. Secondly can you still purchase stock height (plain headlight stands, every where i look all i find is chrome or stainless). Any help would be appreciated. I am putting comercial headlights on a 33 3-window.
Did you check with speedway?
www.speedwaymotors.com
They have one of if not the largest assortments of hotrod and racing parts. Shane |
I believe that the chopped stands will work with the commercial headlights.
Doug T's 34 coupe with Comm headlights IIRC the Commercial headlights are more cone shaped on the back...so they should clear the fender. (looking at the pic in the wescotts catalog it looks the other way around...so now I'm confused.) Try CW Moss for the painted stands if speedway does not have them. Wescotts has them plain. http://www.wescottsauto.com/pdf-g-fo...-headlight.pdf Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-10-2008 at 09:59 AM. |
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
See my edit above..Wescotts has plain ones.
Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Recent General Rodding Tech posts with photos |
| Practical Ride Height 34 Ford | rhphotrod | Suspension - Brakes - Steering | 9 | 12-16-2012 01:19 PM |
| 34 Ford project | rhphotrod | Introduce Yourself | 19 | 06-28-2010 01:08 PM |
| Ford Flathead 8ba to a 34 Ford Trans. | Nailheadforty | Transmission - Rearend | 2 | 05-13-2007 07:31 PM |
| Hemi into 34 Ford? | heyjude076 | General Rodding Tech | 7 | 05-06-2007 08:33 AM |
| 34 Ford Side hood grille/vent? | Pilot34Coupe | Body - Exterior | 5 | 02-28-2003 07:15 AM |
