1933 Dodge Chassis Engineering rear end mounting kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2011, 09:16 PM
Von MoPar's Avatar
Anyone used a Chassis Engineering rear end mounting kit in a 1933 Dodge?
they are listed on page 33 in their catalog....
I would like to know how high (or low) the car sits with this set up......
Old 07-15-2011, 08:02 AM
Cape Cod Bob's Avatar
I used their universal rear leaf sprin kit in my 31 chevy sedan. The rear sits at a good ride height. I used the front perches as the starting point for locating the rear centered on the fenders. Had to make some adjustments. Came out good. I did not weld it in as sent, rather, drilled holes in their bkts. and thru bolted to my frame. The springs are flat with the full weight of the car . The ride is a little to stiff for me. I'm not sure of the shocks. Maybe I could use softer ones or a softer leaf spring altogether.
Eaton will sell you stock replacement springs for the ride you want .With reversed eyes , shackles etc. Think about that. Ofcourse more money then CE.
Old 07-21-2011, 09:01 PM
Von MoPar's Avatar
thanks for the info.....anyone fit the chassis engineering kit to a 33 MoPar?
Chassis Engineering IFS 35hotrod Suspension - Brakes - Steering 15 10-04-2014 11:40 PM
41 ford sedan w/ chassis engineering? fordman67 Suspension - Brakes - Steering 2 03-26-2011 07:05 AM
Chassis Engineering leafs impalalover60 Suspension - Brakes - Steering 5 11-20-2009 09:18 AM
Chassis engineering rear suspension reborn55 Suspension - Brakes - Steering 3 06-30-2008 07:01 AM
chassis Engineering MII suspension bcovey Suspension - Brakes - Steering 5 11-18-2007 12:21 PM
