1934 chevy 1/2 front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2004, 08:10 PM
I purchased a 34 chevy 1/2 pickup. It's completely disasembled. I plan on hot rodding it some day. It has a early nova rear end and wet brakes on the front. I'd like to build a sixties style rod. I don't want to use a mustang to front end. This is my first rod project. Can anyone point me in a good direction to build a trustworthy front end
Old 08-29-2007, 07:40 PM
Possible Solution
EDITED ... By Deuce
Spam is not allowed ...
Last edited by Deuce; 08-31-2007 at 05:50 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 08-30-2007, 12:20 PM
need strog32 chevy front doors
Last journal entry: LittleFloor
wet brakes on the front. Any idea of what frontend you have??? pictures?
Old 08-30-2007, 11:27 PM
powerrodsmike's Avatar
Wiki Edits: 161
Check out the guys at Jim Meyer racing, they make some nice stuff, and it isn't MustangII.
I just did one of their bolt on kits for a 56 chevy. They have a kit for your truck as well..
http://www.jimmeyerracing.com/ifs1.html
lakeshorefab- you need to read the guidelines for posting, no advertising by businesses is allowed.
http://www.hotrodders.com/help/board/guidelines.html
Read this page, it explains the posting rules for businesses..
http://www.hotrodders.com/help/board/business.html
Later, mikey
BE different....ACT normal.
Old 08-31-2007, 05:54 AM
You can recommend other folks you have used ... but you cannot recommend your own business
I understand you are NEW ... so no harm ... no foul ...
But please refrain from spamming the board with your own business.
I would like to WELCOME you here ...
Deuce Moderator
Old 08-31-2007, 11:53 AM
Youngster's Avatar
'34 Chevy 1/2 ton fron end
I'm in the process of building a chassis for a '33 Chevy pickup for a friend. I found that it's hard to get the stance I wanted with the parallel springs, so I build a new front clip for the frame fashioned after a '33 Ford frame. That way I can use an after market front cross member, dropped axle, etc. We aren't running fenders so this was a way to clean up the exposed frame rails too.
If you're going to run the fenders and hood, you could just replace the stock front cross member with the Ford one and crop the stock frame horns to match your fenders.
Youngster
