Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1934 chevy 1/2 front end
Old 08-31-2007, 11:53 AM
Youngster's Avatar
Youngster Youngster is offline
'34 Chevy 1/2 ton fron end
I'm in the process of building a chassis for a '33 Chevy pickup for a friend. I found that it's hard to get the stance I wanted with the parallel springs, so I build a new front clip for the frame fashioned after a '33 Ford frame. That way I can use an after market front cross member, dropped axle, etc. We aren't running fenders so this was a way to clean up the exposed frame rails too.
If you're going to run the fenders and hood, you could just replace the stock front cross member with the Ford one and crop the stock frame horns to match your fenders.
