1934 Chevy Head Lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2011, 01:14 PM
I have halogen headlights on my 34. All new wiring kit and light switch. When I turn on the headlights, they will stay on for about 30 seconds, after that, they blink on an off. Tail lights and tag lights remain on, If I disconnet one headlamp, the other stays on without blinking. I have checked the voltage at both headlamps and they register 13+. I have replaced the light switch and traced all the wires. I can't understand what is wrong.
Old 04-18-2011, 01:38 PM
302 Z28's Avatar
The amperage draw of the halogen headlamps is over loading the built in circuit breaker of your headlamp switch. You need to run your headlamps from a relay in order to remove the load from your headlamp switch. Search this forum for many posts on the subject.
Vince
Old 04-18-2011, 02:45 PM
IdleInvest's Avatar
Headlight Relays
I agree. If it's a newer replacement switch it'll have a built in circuit breaker and the power draw on your system is too great. It sounds like the switch is doing its job and the breaker is blowing and resetting.
The link below should give you info and ways to fix it.
http://alanhorvath.com/54chevy/headlight_relays.php
This next link is real good reading.
http://www.madelectrical.com/electri...adlights.shtml
Good luck
Larry
Head Lights Terrell460 Hotrodding Basics 2 04-20-2011 11:23 AM
accessory lights dim when head lights turned on 36int Electrical 8 04-10-2011 11:59 AM
Brake lights, head lights 40chevy Electrical 9 05-03-2006 08:59 AM
Head lights TransAm96 Electrical 1 06-06-2005 05:24 PM
Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? mistermuscles Transmission - Rearend 0 07-18-2004 05:40 PM
