1934 Dodge DRXX front suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2005, 10:13 PM
Does anyone out there have any front suspension recommendations SPECIFICALLY for a 1934 Dodge DRXX? I am building a "traditional" style highboy 5 window coupe. Although it came with an IFS in 1934, it has lever arm shocks for upper control arms, parts are scarce, and dropped spindles/brake upgrades/etc are non-existent. Is a completely new subframe my only option or is there any way to modify the archaic original setup? I want it LOW and safe enough to handle what the hilborn injected 392 can dish out. At the same time I want a 50's period correct look. Am I asking too much? Any suggestions?
Old 07-25-2005, 05:15 AM
Hello........I would like to WELCOME YOU HERE.....
Those early Mopars can be made into cool Hot Rods.....and have a better frame than the Fords and Chevrolets of the same years. The drawback is.......as you know the IFS.
If you are a competent fabricator.......
A new front cross member could be fabricated and a 4 bar suspension installed...with a dropped axle. A early Ford (28 to 34 ) type front end with a 5 inch drop....would be my suggestion.
Again.....WELCOME
DEUCE......
Old 07-25-2005, 08:40 AM
Thanks Deuce,
I have been leaning towards a drilled straight axle since parts are so readily available, inexpensive, and period correct. Your suggestion of manufacturers? So-cal, Chassis Engineering...? Any thought on the rear? Ford-style ladder bar? 4-link?
As to my fabrication skills I would give myself a B-. I put a Dodge 270 Hemi and Jag IRS in my '49 Studebaker pickup last year. I drive it daily and haven't had any issues yet.
Thanks for the info. Any ideas you may have are greatly appreciated.
I will do an "about me soon". I need to take new photos of all of my toys as my existing files are too big for the site.
Old 07-25-2005, 07:47 PM
30desoto's Avatar
Dodge ain't all bad
moparmontana
There is on place that is available for you to get mopar parts and upgrades for your suspension, with dropped axles and conversions for shocks and a number of uther things you might want, www.butchsrodshop.com
Hope this helps I have a 30 3 window coup Dodge Desoto but installed a tci frontend in it.
Welccome aboard
I use to live in Greatfalls mt. for about 10 years lots of cars still available up there and I know of a few that are still there just hard to get.
30dee
front suspension 38 DeSoto 38 special Suspension - Brakes - Steering 3 06-28-2005 10:36 AM
Mustang II Front Suspension Specs... yekoms Suspension - Brakes - Steering 2 11-21-2004 09:59 PM
How Do I "Check" My Front Suspension ? ? white66coupe Suspension - Brakes - Steering 1 09-13-2004 05:45 PM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 07:58 PM
vw bug front suspension Blob Suspension - Brakes - Steering 5 11-09-2003 06:17 PM
