-   -   1934 ford (http://www.hotrodders.com/forum/1934-ford-235108.html)
mikej6 07-19-2013 03:44 PM
1934 ford
what make and model would fit under a stock 1934 ford with stock fenders?
heard some fords and nova will fit
we are using the 2 parallel springs
327NUT 07-19-2013 04:24 PM
What make and model ...what? would fit under a 34 Ford? Are you talking about suspension?
killeratrod 07-19-2013 04:31 PM
first off we are here to help. but nothing other than the stock frame will fit, but come on man if you need to ask, then you can not build it. buy a frame for $10,000 and put under your 34 .
RWENUTS 07-19-2013 05:25 PM
You sure you don't have a chev. 34 Fords had transverse springs. Chevy's, poncho's, chryslers had parallel leafs.
poncho62 07-19-2013 05:32 PM
He is asking what rear end will fit in his 34, I believe.
