1934 Ford Fiberglass door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2013, 06:09 AM
I need door hinges for right and left side of my 1934 fiberglass body
Old 03-14-2013, 09:19 AM
Wiki Edits: 27
searching time
The problem with buying an imcomplete kit. sometimes the companies will laminate a business card somewhere inside the body to try to see if they are still in business. not all companies used reproduction hinges. You need to check out some other cars to see if original design hinges will work then start contacting vendors, body manufactures. My glass 32, I bought second hand ,,has original roadster hinges, some one took off with a torch and gouged them in a couple places. after pricing repo's I will sand blast, tig weld and refinish them.
Old 03-14-2013, 02:11 PM
FASTFORD's Avatar
try these:
http://www.wescottsauto.com/WebCatal...DeckHinges.pdf
Search Within MAC's Antique Auto Parts
1934 Ford 4 door sedan sky 901 Introduce Yourself 2 01-11-2012 03:04 PM
anyone has a video on "how to install suicide door hinges on a 1937 Ford Humpback" monkeyface Body - Exterior 0 10-27-2011 02:35 PM
Door hinges scottyd Body - Exterior 1 03-25-2008 07:44 PM
Door Hinges for 37 Ford 37FordCoupe Body - Exterior 8 02-10-2007 08:10 PM
49 Ford door hinges Inks Body - Exterior 2 06-06-2006 09:31 AM
