1934 Ford radiator greyhound - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2007, 04:51 PM
Last journal entry: Bringing home the 401 Nailhead
Any tips on spotting an original 34 Ford radiator Greyhound. I see a few at swap meets but never know which are originals and which are repos. Some say originals have testicles but this seems too easy to copy. Any idea of value?
Old 06-02-2007, 08:09 PM
I don't know if this is foolproof, but I think on the originals, the tail is not actually attached to the back leg.
Old 06-03-2007, 10:07 AM
powerrodsmike's Avatar
Wiki Edits: 161
Try this site,
Mikey
BE different....ACT normal.
Old 06-04-2007, 05:34 AM
Thanks Mike. Never thought to search for "mascots". Never thought there were so many versions either. Just my luck too. I have a 32 2dr sedan & a 34 2dr sedan but my "greyhound" mascot is a 33.
Old 06-04-2007, 07:00 PM
Don't think there is such a thing as "original" greyhounds for add on to the old Ford radiator cap or the hood ornament. These were after market items so any that you buy from all the Old Ford parts vendors are just as "original".
Trees
Old 06-06-2007, 01:03 AM
Greyhound accessory radiator caps were factory accessories from Ford in 1933 and 1934 for the Passenger Car line. These were probably made by Stant and other manufacturers. They may have the part numbers cast into them, 40-18390 for 1933 and 40-18390-B for 1934.
Greyhounds for 1932, 1935, 1936 Passenger cars and commercial vehicles were all aftermarket pieces not approved by Ford.
Old 09-01-2012, 11:51 AM
Jmccrack's Avatar
Last journal entry: Inner Fender problems
A little help
I have ordered my 34 grill shell and was wondering , I have a walker rad with no fake rad cap in the center. My grill shell has the piece coming off the top that fits into the hood cut out. What type of hood ornament or cap fits on that?
Old 09-02-2012, 02:11 AM
34 grille
The 34 Ford passenger car grille consists of the chrome-plated grille stamping, the die-cast 2pc. V-8 grille emblem (if a V8 car), the polished stainless trim band that runs around the edge of the grille bar area, the chrome-plated die-cast crankhole cover, the radiator ornament which mounts to the top of the grille and holds the cloisonne Blue and chrome-plated Ford oval emblem and meets the raditor cap at the front of the radiator neck opening, the double beaded asphalt-treated hemp grille lacing which is riveted to the edges of the shell to cushion the hood.
To mount a radiator cap you'll need to have a radiator neck soldered to your upper radiator tank in the correct place.
Old 09-02-2012, 07:37 AM
FASTFORD's Avatar
quote:To mount a radiator cap you'll need to have a radiator neck soldered to your upper radiator tank in the correct place
this is not necessary.
a 34 Ford radiator cap can be held in place on the grille shell by using a plate that spans the cap opening on the underside of the grille & utilizing a longer screw to attach the chrome cap.
Old 09-02-2012, 09:22 AM
Jmccrack's Avatar
Thanks Again
Thanks again Fast Ford
Old 12-09-2012, 01:00 AM
1933 ford mascot
Is your greyhound original?, yes the originals are different than the aftermarkets, they have more detail in the ribs, the underside will have stamped numbers as well and better made. Looking to buy an orginal, thanks
Ford vs Chevy question savman1 Engine 31 10-14-2008 08:13 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
looking for 1934 ford truck grille okey Body - Exterior 1 09-15-2005 08:52 PM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 10:09 PM
