Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1934 Ford radiator greyhound
Old 09-02-2012, 01:11 AM
pasadenahotrod pasadenahotrod is offline
34 grille
The 34 Ford passenger car grille consists of the chrome-plated grille stamping, the die-cast 2pc. V-8 grille emblem (if a V8 car), the polished stainless trim band that runs around the edge of the grille bar area, the chrome-plated die-cast crankhole cover, the radiator ornament which mounts to the top of the grille and holds the cloisonne Blue and chrome-plated Ford oval emblem and meets the raditor cap at the front of the radiator neck opening, the double beaded asphalt-treated hemp grille lacing which is riveted to the edges of the shell to cushion the hood.
To mount a radiator cap you'll need to have a radiator neck soldered to your upper radiator tank in the correct place.
