Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1934 Ford radiator greyhound
Old 09-02-2012, 06:37 AM
FASTFORD's Avatar
FASTFORD FASTFORD is offline
quote:To mount a radiator cap you'll need to have a radiator neck soldered to your upper radiator tank in the correct place
this is not necessary.
a 34 Ford radiator cap can be held in place on the grille shell by using a plate that spans the cap opening on the underside of the grille & utilizing a longer screw to attach the chrome cap.
