1934 Ford transmission with1948 Ford truck engine clutch questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 08:22 AM
I have a 1934 Ford transmission and a 1948 Ford truck motor with an 11" clutch. The pressure plate is hitting throw out bearing shaft on case. What do I have to do to modify/fix problem.
Old 05-20-2011, 12:02 PM
Wiki Edits: 27
flathead experts needed.
This site seems to have mostly late model GM engines, a few fords and mopars. You might have to redrill the flywheel for a smaller clutch or find a flywheel for a 10 or 10 1/2 clutch, You could do a search for some flathead V8 clubs and sites or check out the HAMB site
1934 ford Truck ScottROD34 General Rodding Tech 1 06-02-2009 08:25 AM
1934 ford v8 truck 15cwt shady lane Suspension - Brakes - Steering 2 12-06-2006 12:03 PM
1934 Ford Truck to ratrod RNAmerican General Rodding Tech 1 10-14-2006 08:00 PM
looking for 1934 ford truck grille okey Body - Exterior 1 09-15-2005 08:52 PM
Some ford transmission questions luckyloogy Transmission - Rearend 9 12-29-2002 05:37 AM
