Thread Tools Search this Thread share on Facebook
  #1
Old 11-10-2004, 06:59 AM
1955chevy's Avatar
1955chevy 1955chevy is offline
1935 chevy pickup cab wood
Hi My name is Darius. This is my first message. I need info about a 1935 chevy pickup cab wood kit or is there a steel kit to replace the wood in the cab? Thanks Darius
Register now (free) or login to remove ads
Old 11-10-2004, 07:01 AM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
welcome Darius....................moving this to the "body" forum. You will get better responses there.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 11-10-2004, 09:02 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
chev wood try this guy
http://chevywood.com/index.html
Or in the alternative one can use square steel tube and weld in a sort of internal frame..look through the knowledge base and some of the journals for some more ideas
Probably use the wood if it is desired to have a 100% restore..do the steel if it is a hot rod modified project..
Just a thought on this deal..
Old 12-13-2004, 09:23 PM
1955chevy's Avatar
thanks for the info. darius
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
