Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 06-08-2004, 07:44 AM
stewil's Avatar
stewil stewil is offline
1935 Chevy Tudor Master Sedan
Need interior door locks for the suicide doors. These look like solenoids and screw into a fitting on the door. Any suggestions as to a source for these? Also an interior door handle for the passenger. Thanks
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
