1935 Plymouth 2 dr sedan suspension ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2005, 09:41 AM
I just bought a 1935 plymouth 2 dr sedan out of nebraska and looking to do some sort of rat rod with it. I have done quite a few muscle cars and 50s custom cars in the past but am new to the 30's stuff. just wondering if anyone has links or ideas on suspension set ups for these front ends. Any help or guidance would be greatly appreciated. Thanks.
Old 04-24-2005, 10:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do a search
At one time or another someone here has done or contemplated about any kind of suspension or frame swap one can think of..we have a ton of stuff in the knowledge base..
OMT
Old 04-26-2005, 08:34 PM
dinger's Avatar
A rat rod? I'd use the same front end on it now. Rats are use what you got available. Street rod, I'd mustang 2 suspension. Dan
Old 04-27-2005, 07:34 PM
advanced design's Avatar
Remember, this is to be fun!
Last journal entry: Lead Joint replacement
Fatman will have a suspension for it.
Old 04-27-2005, 07:51 PM
30desoto's Avatar
Dodge ain't all bad
mile-hightoys
If you want to stay ratrod Butchs rod shop has a lot of parts to help lower the frontend and rebuild parts for your car
www.butchsrodshop.com
Mine is more resto rod, good luck on the rod
30dee
Old 11-09-2006, 04:24 PM
I'm not sure if this is where I should reply or not. However here goes. I have a 1935 Plymouth 4 door PJ sedan restro rod. I bought a 3" lowered kit from Butches Rod Shop. It came with everything required including the following --- new 3" drop axel, disk brakes(Chevy), new styls shocks, shocks mounts, cross steering rods, Chevy vega box mount. I stayed with the orginal style parralle springs and adapted the orginal sway bar from the Plymouth. I have a Chevy Nova 373 posi gear rear end with a Nova sway bar. This car rides and handles unblieavable with the orginal style springs. I've been on the road for 4 years now. Now the problem here is Butches Rod Shop is out of business, however you can buy all the same setup fron Chassis Engineering. If this helps and you have more questions get back to me. Bill W.
1938 Plymouth 4-door sedan mahearn Hotrodding Basics 7 10-26-2005 08:38 AM
boxing frame on '33 plymouth sedan nomadbb Suspension - Brakes - Steering 2 03-27-2005 10:44 AM
Help with 53 chev 2 dr sedan roof chop FroFro Body - Exterior 2 05-04-2004 08:29 AM
38 Plymouth sedan body parts B-D Drag Racing Body - Exterior 1 04-02-2003 02:10 PM
wood interior and roof 1935 chevy sedan KC Interior 2 10-18-2002 11:07 PM
