1936 Ford with 9" rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2009, 09:36 PM
I've been building my 1936 Ford 2 door sedan for quite awhile. Every week-end, something new comes up. Current problem I need advice for..........the Ford 9" rear (I don't know the vintage) has slowly leaked out all the fluid I've put in. It's a slow, steady leak, seems to be coming out for sure around the lowest stud, maybe the nearest stud on either side as well. I took it apart, smoothed off the housing and pig surfaces that face one another, used a new gasket, and same result.
Is there any way anyone knows to seal around these lowest studs?
Thanks
Old 11-26-2009, 10:28 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks
The studs may not be drilled as a blind hole which means the hole goes through into the housing. The best thing to do is remove the studs, clean them and the hole threads and apply RTV to the stud threads and re-install. Let the RTV cure and your problem should also be cured.
Old 11-26-2009, 10:47 PM
big gear head's Avatar
High Performance Rear Ends
The studs are pressed in from the inside of the housing. Oil will leak around the studs. Ford used copper washers under the nuts to seal them. I don't know of anyone who puts copper washers on them when they put them back together. I use RTV around the studs and a little more under the nuts before I tighten them up. This seems to work pretty well.
Old 11-27-2009, 09:45 AM
Leaky 9
big gear head is right. Use the copper washers if you can find them. Naturally the leak would show itself at the bottom (lowest point). Make sure the leak is not from the pinion seal, and running off at the bottom. (Been there.)
Old 11-27-2009, 11:30 AM
prostreet6t9's Avatar
Differential/Driveline
Google Chelsea part# 378018. That copper washer fits and works great. It will look a lot nicer.
Old 11-28-2009, 10:13 AM
I ALWAYS use the washers ... and I also use Ny-lok nuts. If your local parts guy does not have the copper washers ... they are always on eBay ... for cheap money
http://cgi.ebay.com/ebaymotors/FORD-...item2a02d72a5d
My center chunk is aluminum ... and gear oil stains LOOK NASTY ... so I always use the ny-loks and washers to keep the aluminum CLEAN
Old 11-28-2009, 11:47 AM
iceman36's Avatar
GM rear end widths info Christmas gift request
Re: Christmas gift request
Iím working on my wife to get a new rear end for Christmas. Ok guys calm down itís for my 36 Truck!
Doing rough measurements on paper, of a selection of wheel back spacingís and body width Iím ending up needing a rear end around 66Ē from wheel mounting surfaces on axel shafts.
To keep things consistent I would like to use something from GM possibly 1988 and up and 6 lug but not floating.
I have charts showing GM made OEM non floating 6 Logs rear ends but canít find actual measurements to know what is even out there to work with.
To save money a junkyard find that I could refurbish and upgrade later would work. I could redesign but would like to keep extra body work down if I can.
So does anyone have information or know of a web site with GM rear end widths info?
Happy thanksgiving to all
And have a Christmas you will never forget Öand a new yearís party you find hard to remember.
Mike
Old 11-28-2009, 03:26 PM
Nut and washer kit
I found a kit on the shelf. It is amkproducts part # F-785 and includes nuts (locking) and washers. 10 of each. An alternate p/n on a sticker on the bag is 4141-2AK. Possibly NPD part #. Application is early (69-73) Mustang. Good Luck! Jeff
Old 12-05-2009, 03:24 PM
iceman36's Avatar
RE: GM rear end Christmas gift request
Hi
A girl I know came buy so I measured her rear end, and the wife let me, cool wife.
Anyway her 2006 6 Lug Chevy Suburban after subtracting the wheel and rims width ended up around 66Ē to 67Ē but not exact.
So I now know the Suburban is a possible candidate.
I would like to ask any one reading this post that has a Suburban in the (late 80s) or newer or any salvage yard if I could get rear end width measurements from end of axle to end of axle, mines wheel and rim, 5 or 6 Lugs and year.
Hopefully I can use the information to call around and find a used rear end to put in my Christmas stocking this year.
Iceman36
Old 12-05-2009, 07:26 PM
If you were not so far away I could fix you up. I've got a complete rebuilt '82 GM truck 8.5 rear end for sale, but you probably don't want to ship one all the way to CA.
Old 12-05-2009, 09:25 PM
iceman36's Avatar
Hi:big gear head
3 Days and 4500mi. is a little excessive for driving and shipping.
Would you be willing to give me some information about it, like width axle to axel, Year, model and 5 or 6 Lug. Also what would you be selling it for?
iceman
Old 12-06-2009, 08:37 AM
I can't remember the total width of it right now. I'll try to remember to measure it later today. It is 5 lug from a 2wd truck, '82 to '87. Seems like it's about 63 inches, but right now that's just a guess.
Old 12-06-2009, 02:23 PM
I measured the truck rear end and it is about 67 1/2 inches, which would be about 67 3/4 with brake drums on it. This is a '82 to '87 GM truck 2wd rear end.
9" FORD REAR TAG propaneburner Transmission - Rearend 3 03-12-2006 03:56 PM
rear bumper brackets for a 1936 Ford blyde Hotrodding Basics 5 02-24-2006 08:17 PM
9" conversion for 48 ford rear end big mal Transmission - Rearend 1 08-23-2005 09:47 PM
Ford 9" w/ rear disc brakes 48Man Suspension - Brakes - Steering 8 07-21-2004 07:58 AM
