1936 Ford and Chevy Drivetrain
I have a 1936 Ford convertible that I am putting a 307 Chevy into. I want to put a total Chevy (4 or 5 speed) trans. and rear into it too.
Anyone have any experience with the chassis modifications needed for trans. Any suggestions for installing a 55 chevy rear end. Any Ideas on converting the mechanical front brakes to hydraulic brakes Thanks Aralph |
blue
every thing needed for this swap is available "after market" all bolt on,no welding needed.contact the rodding markets.55 chev rear will work nicely.
These guys have everything you need. Good quality parts at reasonable prices.
http://www.chassisengineeringinc.com/ Chris |
As I recall, the '55-64 rears were a little weak, that's why Gassers of the day used Olds rear ends-yes, they were a front loader, and I blew up more than a few- |
I to run 55 rearends in my 46 dodge pickup but they did not hold up so I went with a 69 Nova it's been in the truck for about 25 years and it still smokes the tires when I want it to I'm running a 350 in it now it did have a 400 sbc
Went Bronco Rear and 350 SBC in 36 Ford
With all the talk II heard since I posted the info on the 307 and Chevy rear I changed my total direction
I now have a chevy 350 in the 36 and I bought a 1973/74 9" Bronco rear. Troubles again- I am also having a hard time finding what year and HP that I have in the Chevy engine I bought and was only told it was a 350 Truck engine. I can't find those markings on my truck engine. What I do find there is letters GM and 3970010 On the block on the passenger side in front of the head on the tab I find the numbers T6F73830 and VO615TKB. Can anyone please tell me the year and HP Thanks, |
Go here to see for yourself ... http://www.nastyz28.com/gm-chevy-cod...s-suffix-8.php Check the Block date code of the casting for the year ... to see if it is a 1976 or a 1979
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Thanks
That's Cute. I plan to put a 5 speed behind it. Because of the crossmember mount in the center of the X-frame I am forced to use one from an S 10 Truck because the shifter is forward about 10 to 12 inches. I am having a problem with the flywheel hitting the bellhousing.
Does anyone know of a bellhousing that will fit and have bolt holes for the starter? I hear the early V8 ones may fit. Any suggestions? aralph |
It should clear the bell housing. IF not Maybe a V8 Camaro bell housing for a 5 speed. Also Lakewood makes a bell housing with the starter bolts for a 5 speed V8 Chevrolet
Bellhousing
Thanks for the help.
I have found that most ot the S 10 chevy 5 speeds come with bellhousings. Thay also have a bracket for attaching the slave cylinder. Now, if I can find one for sale, I may be all set. [B]Hint[/B]- If anyone has one especially in the NY area please let me know. By the way, if anyone has knowledge about how to remove a side window from a 1936 Ford Convertible (Cabriolet)- Please let me know. Thanks aralph |
| List all of your cars HERE! | Carbed95GT | Hotrodders' Lounge | 289 | 11-09-2011 06:43 PM |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 1936 ford pickup, which chevy rearend fits? | troop1943 | Transmission - Rearend | 1 | 01-08-2009 01:24 PM |
| Ford vs Chevy question | savman1 | Engine | 31 | 10-14-2008 07:13 PM |
| Ford Muscle..what's wrong with them? | tm454 | Hotrodders' Lounge | 41 | 11-20-2006 12:37 PM |
