Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1936 Ford rear fender repair panel and running boards??
Old 04-11-2011, 11:21 AM
Jim H Jim H is offline
I had recently purchased a pair of fender patches (EMS). And was wondering if anyone out there had some experience with installing these? They seem to be a bit larger coming into the wheel opening than they need to be and have a crease in them that does seem to suit any purpose on the 1936 application. Someone had suggested to me before that using as little of the repair panel possible was the way to go. I wanted to get some addition input before cutting anything. So information would be much appreciated.
I also discovered while checking for fit to the running board, after peeling up the rubber. That the running boards are also finished. I looked on Drake site and Mac's, they were surprisingly inexpensive. I am going to go with the covered boards again, but will opt out of the boards with rubber install and save a few bucks. My question is who's boards has the best fit? Or are they all coming from the same manufacturer?
Thanks, JimH
