Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1936 Ford Window Removal From Door
Old 11-26-2010, 06:11 PM
matt167 matt167 is offline
Wiki Edits: 31
I'v never been nice to old glass. just roll the window down a little, and hit it on the edge with a 1/4" socket wrench.. you will need to vacuum up lots of glass tho.. J/K
I'm not sure for your particular car, but www.chevsofthe40s.com has very good illistrations of the door/ door hardware for '37- up in the catalogs, so you should be able to figure out how to get it out pretty easy, as a '36 isn't much diffrent in design
