Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1936 Ford Window Removal From Door
Old 04-30-2012, 09:40 PM
aralph aralph is offline
Last journal entry: Speedometer Connection
Window Removal
As you may have guessed, I put the window on the back burner as I had many other things to do on my 36 Ford in the mean time.
The way I removed the window was to first remove the window regulator from the door. To do this you must have someone hold the glass as you drop the mechanism and guide the arms of the regulator along the track to one of the two small opening in the runner for each arm.
Next, you firmly grasp the window and lift it straight up as it has a large frame that extends about a foot below the window and into tracks on each side.
