Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1936 Oldsmobile Door Wood
Old 08-01-2006, 10:10 PM
Bad Rat's Avatar
Bad Rat Bad Rat is offline
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I think all of the GM fisher bodied cars in 36 had wood reinforced doors, We are just finishing up a 36 chev 4 dr, and we had to replace all the door wood with steel tubing,, quite a task.. after the wood is removed,, all you have left is the outter skin of the door,, I found the best way to do the job is to hang the doors in the opening and get the gaps and reviels the way you want them,, tack weld them to the body so they stay in place,, then build a jig on the door to hold them in shape. where they cannot twist ,, then cut the tack welds loose and move them to a table so you can work on them,, I used 1/2 X 3/4 thin wall tubing and 22 ga sheet metal to reinforce them.. all the area around the windows have to be fabed . including the area where the window track, and garnish moldings mount,, quite a job,, lots of work.. and very time consuming,, to find a wood kit,, you might do a google search,, altho I could not find anyone that makes a 4 dr kit,, one guy in arkansas said he would make a kit for 5K if I would send him the old wood,, to use for patterns,, if the wood was good enough to use for patterns I wouldn't be replacing it,,
I will try to find a picture of the way the jig ws made,,,, good luck,, you'll need it,, Bill
ID:	13828   Click image for larger version
ID:	13830   Click image for larger version
ID:	13832   Click image for larger version
ID:	13833   Click image for larger version
