-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   1937 Buick Roadmaster Dash Welded in? (http://www.hotrodders.com/forum/1937-buick-roadmaster-dash-welded-221321.html)
Mutt's37Buick 07-05-2012 01:47 PM
Does anyone know if the 1937 Buick Roadmaster dash welded in?
I was told that the '37 Buick dashes were bolted in with a stickey adhesive added.
When I look at my '37 Roadmaster the dash appears to be welded in place.
Am I correct, or am I seeing the assembly incorrectly?
Thanks
bob70 07-06-2012 08:16 PM
Buick dash
I quote from Fisher Body Service Manual 1937, which covers the Buick as well as other GM brands.
"The dash panel is a steel stamping electrically spot welded to the cowl upper panel and the cowl side panels...a dash to sill brace is riveted through the dash to the chassis frame brace. The same rivets anchor both of these braces to the dash. These braces form an anchorage for attaching the body front end to the chassis frame.
The dash to chassis frame brace...is used on some style bodies, while a differently formed brace is required for other style bodies. All serve a similar purpose, being riveted to the dash and dash to sill brace in approximately the same manner."
It's a little hard to follow some of the references (braces, etc) but the short answer is that it is welded. The missing words denoted by ... are references to drawings in the book.
Mutt's37Buick 07-09-2012 09:46 AM
Thanks bob70,
This description jives with what I am seeing on the car.
Mutt
