#1
1937 Chev sedan radiator support question
I have had to replace the radiator on my 1937 chev and the new radiator is thicker than the old. As a result it will hit a support rod that is about 12 inches up from the bottom of the radiator. Can this rod (looks like a pipe almost) be cut and just left out, or do you think it will need to be cut and extened toward the rad more than rewelded in to the old mount. The factory piece was not bolted in but spot welded in and part of the original radiator support shell.
Thanks Register now (free) or login to remove ads |
| Thread Tools | Search this Thread |
| Similar Threads for: "1937 Chev sedan radiator support question" | ||||
| 67 Mustang Radiator Support | Stangman196700 | Body - Exterior | 7 | 11-07-2008 01:28 PM |
| Radiator Support 1951 3/4 ton | chevy3600 | Body - Exterior | 0 | 09-15-2008 08:36 PM |
| Radiator support | came to pass | Body - Exterior | 2 | 09-15-2007 10:36 AM |
| 70 nova radiator support | backyard71nova | Body - Exterior | 7 | 08-04-2007 10:38 AM |
| bent radiator support | erockschevy | General Rodding Tech | 10 | 11-01-2004 03:24 PM |
