-   -   1937 chevy coupe rear brake drums (http://www.hotrodders.com/forum/1937-chevy-coupe-rear-brake-drums-177339.html)
a70dart 05-04-2010 10:29 AM
I purchased a vehicle that was about 95% completed before owner passed away.
Previous owner had all brake parts, so I installed all the new parts and appears that the used brake drums are too narrow. Loks like the brake shoes and wheel cylinders are rubbing once lugnuts are tightened.
I measured it and appears the brake drum should be 3/8 to 7/16 wider to miss these parts. It does look like he has the correct shoes and wheel cylinders. I have looked online and some show drums without indentions and some show with.
I thought there may be someone that has run into this problem and can shed some light before spending $$$$ on new drums that may not work.
Thanks
matts37chev 05-04-2010 01:03 PM
2 Attachment(s)
heres a pic of mine, hope it helps
a70dart 05-04-2010 08:16 PM
Thanks, your drums look the same. Yours are about 1/2 inch deeper than mine. I guess that is the issue. I have a Dan from Kanter auto parts looking into that for me.
I will let you know.
