1937 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2003, 04:15 PM
Post 1937 chevy pickup
I'm looking to pick someone's brain here.I'm building a 37 chevy 1/2 ton into a resto rod and am keeping the stock straight axle.
I already have the disc brake parts and new springs and am working on the steering system now.
My problem lies in what to do for a box? When I put a newer saginaw box inside the frame i no longer have room for my big block (any block for that matter).If I place the steering box outside the frame but ahead of the axle it looks nearly impossible to run the steering shaft.
Has anydody done this before ? and if so I'd be gratefull if you could tell me how you did it.
Rob
Old 01-04-2003, 06:32 PM
OddRodder's Avatar
CORNFED and INBRED !?!
Post
This answer may be of little help, as I really can't see your truck. Have you looked into using a more compact steering box, such as a Vega unit? Look at speedwaymotors.com for a steering box along with pitman arm, steering joints, and shaft to hook it all up. A rack and pinion set up really isn't an option with a straight axle, so finding a steering box that works is the only way to go! Best of Luck! <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 01-04-2003, 06:56 PM
Post
Thanks Oddrodder.
I'm trying not to spend the thousand bucks for a vega box. That's what they cost here with currency exchange and duty and taxes.
None in the wrecking yards either.Any other ideas?
Rob
Old 03-26-2011, 08:14 PM
Buckeye Bob's Avatar
I dont know if this will help you or notbut i put a p/s box from a 1988 IZUZU
TROOPER it is small & fit right on the frame of my 53 mercury,even the pitman arm fit & i got it out of a junkyard for $20.Check it out you have nothing to lose. BOB
