1937 pontiac dimmer switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2003, 11:26 AM
Post 1937 pontiac dimmer switch
I'm about to re-wire my '37 pontiac from original wiring to a new harness. Everything looks fairly do-able. I see only one (and this is before I have actually started) problem. It's the Dimmer switch on the floor - How do I access it to re-wire. I've crawled over and under, removed the floor plate under the clutch/brake/gas pedals. I do not see any way to remove or get to the wiring mechanism under the dimmer switch. Anyone out there know how to get to it? Also should I expect any other surprises on wiring the new harness?
Thanks
Bill T
[ March 21, 2003: Message edited by: bill thomas ]</p>
Old 03-20-2003, 11:37 AM
EBlack36's Avatar
Rebuilt Excitment
Post
I have a 36 and If I remember correctly it comes up through the toe board from the bottom. are you making it a street rod or restoring it? Mine is a street rod and when I rewired it put a 60's unit on top of the floorboard.
Old 03-20-2003, 12:24 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post
Hey, Bill
Mine is mounted from below with screws - fairly obvious ... so I'm not sure what's up with yours.
I just ordered and received a 21-circuit/18-fuse kit from EZ-Wire - <a href="http://www.ezwiring.com/" target="_blank">http://www.ezwiring.com/</a> - I also ordered a new dimmer switch and headlight switch to install at the same time. They don't include grounding wires, so I bought a roll of 12 gauge machine/tool wire from Home Depot for $7 (gas & oil resistant).
The kits wires are all color coded and labeled every 5 inches. Looks easy enough!
Good luck with yours, bro'!
Alan Horvath
<a href="http://AlanHorvath.com/" target="_blank">http://AlanHorvath.com/</a>
