#1
1938 ford rearend disassembly
i cant figure out how to got the rear brake drum off im pretty smart but this is testing my integrity
Register now (free) or login to remove ads |
#2
Welcomew to the site post here (Suspension - Brakes - Steering )and someone will help you out.
Cole |
#3
You need a puller like the one in the thumbnail below, or the better one that grabs the groove around the hub.
The axle shaft is a tapered fit into the hub, and they are a royal PITA to get off if they have been on for a few years..get the acetelyne torch and heat and beat on the hub if you have to..Pry the little felt washer out after you take out the nut and soak the thing in kroil or liquid wrench. I made a special steel guard to put over the end of the threaded part of the axle so the puller bolt wouldn't mushroom out the end of the axle when I was cranking on it..made out of an old axle nut and a piece of 1/4" steel, with a washer on it to center the puller bolt. Atomic bomb works too. Once you get it off, check the hub, bearing and bearing journal that is the end of the axle shaft. They are usually pretty tore up. I've put the replacement journals on for folks, and also put the late model ford axle conversion, (the one with pressed on bearings, uses ford 8" axles).. later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike : 05-17-2010 at 10:35 PM. |
| Thread Tools | Search this Thread |
| Similar Threads for: "1938 ford rearend disassembly" | ||||
| Ford 8.8 Explorer rearend spring perches? | fasteddy51 | Suspension - Brakes - Steering | 6 | 09-17-2009 10:54 AM |
| Ford 9" axles in a 10 bolt Chevy rearend. | RP40 | Transmission - Rearend | 2 | 12-14-2008 12:26 PM |
| ford rearend in a chevy | jo5hi3 | Transmission - Rearend | 2 | 12-06-2003 11:11 AM |
| JAG REAREND INSTALL 56 FORD F-100 | Beedog69 | Transmission - Rearend | 2 | 07-11-2003 05:46 PM |
| ford rearend for 33? | nick | Transmission - Rearend | 2 | 11-06-2001 10:58 PM |
