1938 Pontiac Coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2010, 12:14 PM
1938 Pontiac Coupe
I am told that the Canadian Pontiac frame under my 38 Pontiac may be slightly different than an American frame(not sure)??? Does anyone have any experience in placing a modern frame or otherwise have other options for a platform under a 38 Pontiac Coupe? Thx for the consideration!
Old 01-15-2010, 07:51 AM
Wiki Edits: 27
tech article
There is a WiKi tech article here under suspensions, It might be hard to find all the factory parts they used. Some frame swaps can be easy and others can be a real pain. I would want to check out someone's build first. a front clip might be easier.
Old 01-15-2010, 10:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Somewhere I have photos of a '40 (see my avatar) Pontiac frame that was taken when I had it apart for restoration, if that would help.
A common approach for using an existing (as opposed to a custom) frame is one from an S-10 or clones. It has disc brakes, can be had w/an 8.5" 10-bolt rear end, is capable of holding most any engine, and is common.
Obviously, changes may be needed to accommodate the wheel base, etc.
Old 01-22-2010, 09:21 AM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
frame lame?
Hi, I have a journal about my 39 Deluxe Coupe (search rwruther in the journals). I kept my stock frame, just added dropped spindle supports, shock mounts up front, 350/700R4, camaro rear end, drums all around. Send me pics of yours rwruther@wowway.com, I'll respond with pics of mine.
Hey, get any snow up there? (ha ha, little usa humor)
R
Old 01-22-2010, 03:23 PM
Rufus_2's Avatar
Last journal entry: Long time no post
I have a 37 Pontiac sedan that I modified the original frame. I used a Fatman Fabrications Front Stub to provide the modern front suspension. Out back, I removed the leaf springs and added a triangulated 4 link with coil overs. I boxed the rails and opened the center of the X to accomidate the new transmission.
When it was all said and done the cost for the changes was around $5,000 but that was to get a full rolling chassis. Most new rolling chassis setups I've found are in the $8,000 to $10,000 range.
Take a look at my journal to see if my frame is the same as yours. In the US, Pontiac used the same frame in 37 abd 38.
Old 01-24-2010, 06:18 PM
Thanks,EH!
Rufus (and Ruther), thanks for the advice and connection to your journal. It looks like the same frame with the mid X pieces. As soon as I can crawl under the Coupe (YES Ruther we have just a tad of the flying white stuff) I'll do a better line up.
Cheers and Thx Good fellas
Old 01-24-2010, 06:20 PM
Thanks
Sorry, Cobalt and Timothale....cheers and thanks to you also!
Old 02-04-2010, 10:19 PM
Most 1938 Canadian Pontiacs are actually Chevrolet cars with front sheetmetal to make it resemble a USA built Pontiac.
Does your car have 1)flathead 6 or 2)216 OHV 6 or 3)224 OHV 6?
I just read that this is a coupe. Does it have a single back window or split back window?
If you get me the full GM Canada model# and serial# from the firewall tag, I can deciper this for you.
Tim
41 ford coupe fabricator Hotrodding Basics 13 04-05-2015 08:32 AM
what's up with pontiac engines (or BOPs) bullheimer Engine 15 09-11-2009 09:57 PM
1938 plymouth buisnessman coupe redlineharleys Interior 4 01-09-2007 02:38 PM
********* Coupe Parts Fred R. Golightly Body - Exterior 1 12-24-2006 07:23 AM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
