1939 Chev 1/2 headliner - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2006, 03:06 PM
I'm looking for the trim that hold the headliner in on my 1939 1/2 Chevy truck. I've looked on ebay and area swap meets with no luck. There are two metal strips, one for the front and one for the back. Can anyone help?
Old 11-26-2006, 09:19 PM
stea's Avatar
I found mine on ebay a while ago so keep looking. Also go to www.stovebolt.com and check the ads. If none are listed put a post in the "parts wanted" section. Someone will help you out.
Old 11-27-2006, 01:43 PM
You can probably make something up using aluminum shaped strips. These can be bought in any larger city and over the internet (search "aluminum shapes"). They have various widths and surface curvatures and are usually easily formed to fit. You'll have to drill the mounting screw holes after you have the pieces cut and bent. Use oval head screws and countersink the holes and they'll look great, painted or polished or natural finish.
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-09-2006 12:46 AM
Headliner help. Javelin360 Interior 10 07-24-2006 11:46 AM
1939 85 Master Deluxe Chev pudsey66 Introduce Yourself 2 04-14-2006 02:25 PM
Headliner gripper strip question on my 49 Fleetline Rodrunner Interior 2 05-27-2004 08:41 AM
Pinto in my 48 Chev 1/2 ton Larry Day Suspension - Brakes - Steering 8 10-03-2003 07:29 PM
